Assuming the following:
1. the Lexion 760 will harvest 1500 bu/hr in wheat each
2. combine hoppers are 360 bu
3. 1200 bu/hr/combine in canola
4. fields are dry
5. bins are never more than 1 mile from the field the combines are in
6. tridrive truck can dump on the go and come away with 800 bushels after dumping the second combine.
Would one tridrive truck be able to keep up to the two combines in wheat and canola if it were dumping in a 14" Meridian swing auger? (claimed capacity of 15000 bu/hr)
If not would a 16 inch make the difference?
Is it worth buying a tridrive to find out?
Two tractor units with tridem trailers would have 40 minutes per load which is tons of time but we only have one reliable truck driver. (who loves to run non stop and would find 40 minute per load boring) We currently only own 1 tractor/tridem trailer but could buy a second for about $120,000. How hard is to find a second driver who could be trusted with the task of using a semi to dump the combines and drive through the field ect?
Buying a grain cart and installing a PTO in the 4wd is about $130,000 option that leaves you with a piece of equipment that can only be used a couple weeks out of the year.
I've been wrestling with this and have a hard time coming up with the perfect solution so I am open to your thoughts.
4. fields are dry
