Anyone ever had problems with a 1010 reel on a 16 series case header (1644 in this instance)? Left hand side of the reel will drop but the right will not, left hand side is a slave cylinder with oil supplied by the right hand ram, new seals have been put in both rams but still only the left hand side drops, tried multiple times to bleed air out of the system but nothing works. Tried plugging the reel supply hose on to a tractor remote and the left hand side didn’t sag at all over night so must be a problem with the lift valve on the header but not sure where to look
