1010 reel surge
1454 Views 1 Reply 2 Participants Last post by  caseihaxialflow
I run a 30 ft 1010 on a 2388 and a 25 ft 1010 on a 1680. The reels on the 30 ft have started to surge. A few years back the 1680 was surging so I changed out the hydraulic relay block and adjusted a pot on it to fine tune it and solved the problem. The 23 series does not have a block. Playing with the manual reel speed dial helps but it still surges. Is there a solution?
1 - 2 of 2 Posts
Check the reel drive relief pressure. If it is not correct you may need to add or remove shims. Best to get a dealer have a look at it. Pretty quick and easy job - usually
1 - 2 of 2 Posts
