I have a 2388 with field tracker and want my header to work with the field tracker automatically. Has anyone else done this. I am guessing that it comes in a kit, how hard is it to change?
do you have the potentiometers on the header if not last i heard it was around 500 for the kit on the header if it is on there just turn the switch on the rh console from "M" to "A"
Discussion Starter #3
The head only has one pot. and it is right in the middle of the head. Can someone help track down a part number for the kit? serial number for the head is JJCO331007. I stood at the parts counter yesterday for an hour and they could not find anything!!! any and all help is appreciated.
call twete inc devils lake nd, call right away in morn about 7 am, ask for larry 1-800-726-7614, scott.
Discussion Starter #6
Yea, Larry was out. She said on vaccation, but called around 7:15 this morning. I talked to some other guy, they had a kit around $800. A little steeper than what I was expecting, but may go ahead and pull the trigger. appreciate all the help.
Scott or Kirby farm I was wondering if you new what the part number for this kit is, I have searched everywhere and cannot find this kit you talk about I even phoned Larry like you said. Is this a case part or jobber? I can find the parts i need in the parts manual but it will cost over 2000 dollars and that is real steep. Any help or suggestions would be greatly appreciated
