1 - 2 of 2 Posts
I need to remove several of the stalk roller spirals what is the easiest way to get the pins that hold them on out and is the easiest way to get them off use a puller and some heat?
They are a nightmare!
I use the torch to burn out as much of the pin as possible then it will come out. Sliding it off the shaft ain't so bad.
The worst is either the bearing or putting new knives on and setting the gaps.
Nothing fun about the project
1 - 2 of 2 Posts
