1 - 20 of 51 Posts
Looking at upgrading my trucking this year. 90% is field to home. Should I be looking for a 13 or 18spd truck to pull a tridem hopper trailer? 85% will be gravel country roads. Lot better selection and in budget with a 13spd.
If your going to be in the field I would definatley go with a 18. It is so much easier to drive when the fields are soft because you can split the bottom end and shift without grinding or coming to a stop because you missed the shift.
I think 18 are at a premium because they are normally speced a little heavier also from what I see. I prefer the 18 but a 13 works well also. Find a truck you like and don't worry if it's only got a 13 in it
I have an 18 spd eaton ultra shift. It works real well in all conditions soft fields etc.
The real question is not the tranny, both the 13 and 18 are great...
The engine in front of the transmission is much more important... This thread is not asking the difference between a 7spd and a 18...
Get a big Cummins or Cat... More torque motor then a Detroit... But it really matters what kind of power you will have.
An 18 speed has a lower gear for better startability. Low gear on an 18 speed is 14.40:1 and a 13 is 12.31:1 . 18 speed has a almost 17% lower first gear. we have both and the 18 is definately better even though the rear axle ratio is a lot faster than the one in our 13.
Oh please. Give me a 14.0 Detroit. Cheap to fuel, run, maintain and rebuild. Series 60 all the way.
Any doubt go to www.ss60pd.com and let Eric tune her up. A Cat or Cummins cant touch a Detroit series 60 for cost of ownership.
Adam
Maybe that has a lot to say where you are from. There are a bunch of s60 around here that are injector eaters because they dont stand up to what a super b needs. if your gvw is 80000# i wouldnt be scared of one either. heck i would even consider an m11.
That is debatable... But a 14l Detroit from 02?-05 is a great engine... But as far as power... Not likely...
I drive over the road, and the one thing I can say about a cat, is it doesn't leave you stranded.... (Pre-2004)
650+- horsepower getting 6.8 winter and 8.2 summer,,, pulling 47k on a flatbed,, from Wi to Denver...
Its all about the driver...
with that horsepower i'd try to get a 18 speed, splitting bottom on soft fields is nice.
I have to say our detroit is indeed our cheapest engine to run, but are indeed piss poor for performance lol but ya it has an 18 speed for that reason.
Total agree, that is why you would need to look at the engine first.
Horsepower won't break things... A cowboy will...
18 speed is the best, gives you an easier time for getting rolling over soft fields but you can get by with the 13. What kind of rear end ratio are you looking at? What duramaximizer says about Detroit series 60 is true but the big Cummins or Cat will give you more grunt. If your going 13 speed, look for lower rear end ratio and more power.
1 - 20 of 51 Posts
