Hey all,
I currently have potential access to 2, maybe 3 GM 14 bolt (10.5") full-floating axles. I'm thinking of cutting the outers off, and putting them on a straight 3.5" tube (thats the OD of the axle tubes, I believe), with new spring perches. Or, grind the welds on the diff housing, and slide a bigger piece of tubing over the axle tubes. This would be to create a pair of dual-wheel trailer axles.
These axles are rated for 8600 lbs GVWR maximum, as far as I know. Any idea what the limiting factor would be? It would be nice to get 10,000 lbs out of each. I'm not interested in running tridem singles. I also don't know if this is legal for Alberta, for Ontario there are ways around it.
Any thoughts? I'm not worried about hydraulic brakes.
Bruce
Bruce
