I picked up a 1460 last week, and I have a couple of questions. First off it has a rock trap and we haven't ever run one. Anything special about them and how do they work? How common was hydraulic fore and aft on them? Why only 2 lift cylinders? Our 1440 has 3. Will it lift a 6rn head ok? Does anybody know the part numbers to convert an 820 cable head to electric AHHC? I would like to update heads but that will probably be next year.
i have a 1440 with only 2 lift cylinders and a 863 corn head it lifts it just fine i wouldnt worry about it. and theres not much weight differance in a 963 & 1063 verses a 863 and also ive never seen a 14 series combine with fore & aft i would think that would have came off a newer machine hope this helps
It was added, just add another vavle to the stack, run the hoses ,wires,and a switch and your in there. The 820's were the same, the control linkage runs down the top of the head into the end of the frame, behind the shield on the wobble-box end, and the electric "pot" mounts to the end of the linkage. Find an elecrtic one, or look in the heads om, and take a look, should be easey to switch.
