Hi!
Have problem with the unloading auger on my 1460. The unloading auger will not move in or out.
When disconnecting the hydraulic hoses from the electric valves I found that there is oil flowing out from one of the valves when turning the auger in/out switch, always from the same valve no matter which direction you turn the switch. When hoses are connected the auger will not move.
Electric valve may be stuck open?
Is it possible to check and cure in situ or should I have the complete valve block removed and checked in some hydraulics repair shop?
Any suggestions how to proceed?
Best regards,
MarkusT
Best regards,
MarkusT
