I am updating 1470 and installing the kit CaseIH sells so that you can adjust the pinch point on the concaves, such as the 1660 had. There are no instructions in the kit. These are the brackets that are on the right side of the machine that the pipe for the concaves mounts into. The original hangers used 3 half inch bolts to secure. The new brackets use 5 five eights bolts. There are two holes that match the original holes. I assume that you drill them to the new size and then use the brackets as a template to locate the other three holes. Is that correct? My local combine guru is gone for a few days and was hoping to get this done over the weekend. Does not look like much fun getting to the back bracket to drill the holes. Would pulling the return tube that goes into the rotor cage help any. I have the sieves out for other work but still really beyond reach going in from the back. I have the old brackets out. Installing new concaves and it was suggested that this kit be installed at the same time. The kit is pictured on page 39 of the 2005/2006 product support kits book. Thanks for any help. Dennis
