For starters the hole is offset to the left, more header would hang out to your right when driving.
The 1482's had an electric/variable speed belt drive for pick-up speed, and a sprocket chain coupler for the auger drive. All drive issues could be solved in an hour or so, take the sprocket off header and the 1480 hex sleeve should slide right on. Take all the pick-up drive stuff off and put a hydraulic motor on pick-up and connect the hoses.
With the prices that wreckers are asking for major parts and complete 815/1015 headers i would consider it if i was only swathing part of my acres.
The 1015 off a 1682 would be much nicer, wider pickup, already hyd drive, and larger diameter auger . Still offset a couple feet but tolerable and much cheaper than one off an SP.
