Anyone have a drawing are video for changing the hyd. pump drive belt on a 1480. I have read what I could find on it and still having problems. Trying to avoid having to pull the whole assembly. Thanks for any info, and just found this site and love it.
The pulley inside the housing will slide over on the splines of the hydro pump. Clean the splines with air as best you can. Unbolt the pulley/hub assembly from the pto side and slide it over onto the splines. This will clear enough room to get the belt between the shaft and pto.
The pulley will separate from a hub that has the female splines to drive the hydro pump. Clean that all up well and check the condition of the hub and pump splines for wear.
