1 - 2 of 2 Posts
Make sure it's as straight as possible and weld some balancing weights to the outside back edge of the spiral.
You can do this without balancing machinery by spinning it between two bearings and heat shrinking the high points with a blowtorch, then pouring water on to shrink the pipe in at the heat point.
1 - 2 of 2 Posts
