I recently purchased a caseih 1620 with the d358 engine. Everything looks to be in good shape except the harmonic balancer/ dampener wobbles at low idle. At high idle it runs straight, the dampener looks to be solidly mounted on the crank so I think it's in the rubber part. Is the something to be worried about and replace with it just happening at low idle? Whats a good source for this part?
Thanks for the help
Look on the dampener it will have two center punch marks, one on the inner half and one on the outer that line up with each other, if they dont, replace it.
The dampener has tapered wedge rings between the crank and dampener, they can be installed wrong and it will wobble.
