Unloading auger will not swing back, I don't have power at the switch on the column or any of the limit switchs. Were does this get its power?, don't have any fuses blown. is there a relay for this somewhere?
The power supply to the switch on the steering column is fed through the limit switches. If either is stuck open you won't have power at the control switch. Since the auger is out the problem is most likely with the rear limit switch.
We had trouble with that at the beginning of this season, it would fold out but not in. We started using a jumper wire off the header solenoid until a rainy day when we had time to fix it. We tested both the switch and the sensors on auger and all seemed to be working. I took the access panel off the right side of the cab and cleaned out the dust to find a mouse had chewed on the wires. Fixed the grounded wires and that fixed the auger.
The most likely cause is the saddle switch at the rear of the machine if it won't fold in, if it won't fold out the limit switch on the elbow is the most likely cause.
