The field tracker in my '90 1680 is acting like it is not getting power. I redid the ground, and attached the power directly to the switched panel. I have 12 volts at the header hight switch where I wired the two connections together to bypass the switch. I pulled two relays and put in two new one's to start with. The circit breaker is not triped, and yes I have the switch on.
That is all the farther I have gotten, any other ideas. The red indicator light will not come on and the controls do nothing. Is there a fuze somewhere beside the 5 amp circit breaker?
