Hi there. I have an older 1680 that has the stack valve up by the cab. The pump tests fine and the primary prv tests fine. The problem happened sitting in the barn. I ran it about 3 months ago and all was good. Let it sit and now no hydraulics. Propulsion works fine. No steering, no header raise, no reel raise, and no auger swing. I have flow to the stack and all plugs and spools have been pulled and cleaned. All electronics are proper according to my service manual. All the solenoids activate and have proper voltage. I shimed the secondary prv, no change.
I'm running out of options here. I isolated the steering from the stack and still no change, so I know the steering is'nt it.
One other thing is I pressure washed the stack valve when I last moved it. Is there another safety relay or something somewhere close to the stack that I cant see from the top cover removed? What else have i over looked?
Thanks for any help.
