I need help trouble shooting electical problems with my 1680. When I first start using the machine everything appears to be working well and then after about 15 to 20 minutes of use I seem to be losing electical power. The first thing to go is my header raising up and down and as of now it will not work at all. I do have power going to my header solenoid, however, nothing happens pass that. Does this mean the solenoid went bad all of the sudden? One other note that the machine is doing is when I swing the unload auger out the light comes on and then it starts to flicker and when this happens things go bad. The auger will not retract the header quit working. I been hunting lose ground wires but no luck. Does anyone have sound advice for me or run into this kind of problem before. The machine would start working if I let it sit for 30 minutes, however, as of now I cannot get the header started.
