1 - 2 of 2 Posts
Field tracker seems to quit working after machine gets warmed up.had two dealer mechanics look at it .went through wiring potentiometers everything could think of. When it stops working it's still sending weak voltage 7or8 volts to one side of field tracker valve ,can hear oil trying to move
You might wanna pull wires out of header to check for mice damage if you havn't already done so. Double check at your header connector for corrosion and or connectivity .
1 - 2 of 2 Posts
