1 - 20 of 22 Posts
I found a 1992 9400 2wd with a hole in its engine block that I might be able to get for $15,000. It has 3100 seperator hours and is in otherwise good shape.
Would this be a good deal? If so, how much would an engine from a burned combine or something like that cost me?
Thanks for your input.
I know you say it is a 1992, but which engine does it have, the 359 or 414?
Can you do the work yourself, or will you have to hire it done?
Unless you steal an engine (i.e. get it really cheap, don't actually steal one, and I put this in here because someone on this site will really think I am telling you to steal it) and do the work yourself, listen to markat425.
Well 3000 hrs are pretty low hr's for that year,My opinion if you can get an engine for that 5000.mark you would have a pretty cheap combine,I have run 9400's for years and they are very relyable,I guess if I needed a combine I would grab this one,I heard on RFD TV a couple weeks ago that good 9400's in nice shape and low hr's bring as much a 80.000 for a 97,model.with most bringing50+
also the engine is very easy to change.
The combiner
I will change my tune.
I was thinking $25-30,000 for early 90s 9400s, but thecombiner is right. I did a quick check on Tractorhouse and you would be lucky to get 92 9400 in good shape/3100 hours for under $35,000.
If it is a 92, it should have the 414 engine. If you can switch it all out for less than $15,000, it should be an ok deal. Finding the engine may be the tough part.
Discussion Starter · #10 ·
See, now you guys are putting ideas back in my head. I was checking on tractorhouse too and thought it would be worth it but decided against it. Now I'm changing my thinking again.
If I could somehow find an engine for under $10,000, maybe it might go. The big farmer I work for has a huge shop and I know he would let me use it and my more mechanically inclined coworkers would probably help me for a few cases of beer.
But like you guys said, where do I find an engine? Are there any tractors or other combines that run that bigger engine? Would it be very hard to put an engine from say a 9500 or 9600 or something like that if I found one?
First, verify it is a 414, it should be.
That is a popular engine in the 7000 series tractors and used in the 94x0 walker combines and then the 9550 walker and 9560 and 9570 STS in multi valve versions. There should be some around.
I suggest calling Abilene Machine:
1 800 255 0337 Solomon, KS location
1 800 866 1504 Belmond, IA location
Their website is www.abilenemachine.com/
Since you have access to a shop and help, it certainly is worth looking into.
Also, just check with your local dealer, you never know what they might have laying around, or may be able to source one.
Dude, IMHO, there's no hmmmm about it. I know it's easy to spend other people's money, so be very careful about the rest of the machine, but sure seems you'll end up with a very nice machine for less than 20k. And, I'll say, I've never changed an engine on a combine, but I wouldn't be scared to try, I can visualize it as being fairly straight forward.
Good luck to you, you have an interesting decision on your hands.
You would be better off getting a take out engine that has never been overhauled, Abilene can sell these to you too. Stay away from anything they have thats been overhauled, short blocks long doesnt matter. Ive even had problems with bare blocks they said maged good.
Discussion Starter · #20 ·
I chickened out on the combine, I'm just not comfortable buying something needing a new engine.
I've hemmed and hawed around on this board lately asking about several pieces of equipment I had interest in buying but never had the guts to buy anything. I finally pulled the trigger on a 2000 JD 7510 from Mississippi on ebay. I don't need the tractor really but considering the deal I got on it I can bring it up here and trade it for something I do need and get a road trip out of the deal as well.
Thanks for your attention anyway. If things go good for me this year I might be looking at buying more stuff.
1 - 20 of 22 Posts
