The engine RPM gage in the cab shows 2300 with no load. Manual says RPM's should have been set at the factory between 2350 to 2450. Do I need to have the RPM's adjusted or in the 2300 correct. This is a cummings engine
Cylinder RPM's in low range are from 60 to 400 on the gage in the cab. Manual says 200 to 524. What would be causing the difference--gage, speed sensor, or a problem with the variable speed. I have not tried the high range yet.
