Check the reel hydraulic pump, located behind the ladder side drive tire. Had the pump go on an 09 9770 this fall. If you roll the belt off, you should feel some resistance spinning the pump by hand one direction. When our pump went bad, it spun freely both ways.
I thought a key had sheared or something, but there were no visible signs of trouble. New pump solved our problem.
