1 - 11 of 11 Posts
The L shaped bracket with square tubing on top came with air reel and that's how air reel is attached to header.Also In the first pic you can see a bolt half way in on the green arm,that is just a stop bolt u should put in to prevent reel from being pushed all the way forward when air reel in on header.You will not ever need it all the way forward with air reel on and is easy to remove when air reel is not used,it is installed about at half way make of reel fore/aft position.On our s670' when we first got the air reels, dealer had to come out and increase oil preasuere on the valve block that sends oil to the reel lift cylinders because air reel is heavey and is mounted far out on the reel.You might not have that problem on the s680's because they have different hydraulics.But if you do have to adjust preasure heat up hydro oil first,don't do it when it's cold cause when is get's hot You'll have to do it again.
Throw of those big useless clunky deere crop dividers and built you own like in pictures,this particular guy just does not like to paint so his are rusted.
Yes Matt I knew that was you, that's why I was being so helpfull, You'r using a new profile and name.
Discussion Starter #11
Hav u ever had problems on the 635 f wer the lateral tilt dosnt wanna return to the right side the left side works perfect it does it on all 4 comebines
1 - 11 of 11 Posts
