1 - 2 of 2 Posts
We just bought a 2013 550 quad this spring and it has about 700hrs on it. We pulled a field cultivator with it this spring and notice no issues. Now this fall we have pulled a 30ft chisel plow with it and a 9 shank ripper and now that its under a decent load when pulling it seems to have a bad drivetrain vibration. Has anyone heard of this and what the issue is or the fix may be? It's not fun to run anymore. Thanks.
Inspect dampner that bolts to flywheel/attaches driveshaft to transmission, should be no cracks visible, check u-joints, on rear of transmission to rear pivot point, there are bolts that retain carrier, is shaft centered? Scott.
1 - 2 of 2 Posts
