hi I'm new to the forum and i'm from quebec province, I installed one in my 86' 1460 and it works great it was pretty simple ,however, i don't know if it's the same system on newer machines, first i went to a salvage and get a relay box from a nissan quest , you have to use relays whitout diodes, put a main realy i think it was 50 amperes and fuse all the circuit ,we had to remove the plastic cover and cut it in the corner of the reverse position and reweld it larger to alow the new hydro handle who is bigger the only thing remainig for me is that the switch for the unloader auger won't stay in position when you leave it, case ih made two switches avaible, one who stays in place and one that doesn't the reason is that i would have to put limit switches like production machines for the rest everything was pretty much simple it cost me about 1600$ but i had to put all new parts because there was no used because they were all burned so..that's it
