Hi. I have to reseed some canola. I picked the same setting I used previously and it have me 5 lb per ac. I was applying fert at same time. Now I'm applying just seed and my rate is all over. Way to low and even if I go to smaller sprockets it still is too low. I used a 42 tooth before. and now I'm on 35 and still not good should i throw seed in front tank and take off drive chain or to I adjust dual pressurization valve? Thank you
First off check your TKW of your seed lots. I seeded 3 different lots this year and sprocket selection was completely different, as high as 42 tooth for 5.16 pounds to 25 tooth for 6 pounds. Nothing to do with less product on my experience, if your tanks are pressurized you should be okay. I'd drop your fan speed though.
I cant remember for sure but I believe there is a pipe that goes between the two tanks on the inside just below the lids. If you are just using the one tank there is a cap you screw on this pipe, I believe our 2155tank was set up like this.
