The 2152/d60 what bits do you have to do to change from CNH to go on a70 series deere? I would say pto shaft , hydraulic coupler and bit of tin work?
A completion kit from Macdon. Part no: B4811. About $3300 AUS . Gives you everything. PTO, hyd coupler and hose kit, tin covers, window frame. Easy to change over.
Feeder drum drive sprocket stays the same for CNH and JD.
