1 - 2 of 2 Posts
My 2188 is putting hytran in the transmission and losing in the reservoir. We put a hydro seal in but did not help. I am going to rebuild the power brakes. Is this complicated and what do I need to know? Any advice would be greatly appreciated.
it will probably be the right one it seems like it is always that one . it is a tricky job putting the assembly back together without cutting the o-rings. any more we put reman brakes on and away they go. It is spring applied and hydraulic released so you will need a compression tool to remove snap rings and then rebuild. my advice buy a reman although it is a grand
1 - 2 of 2 Posts
