This fall we've been having problems with our feeder drive belt slipping. Its been slipping when were running our corn head and our row crop head. In the corn it would start to slip when we were running over 4.5 mph and with our row crop were having problems when were picking up the down milo and trying to run much over 3.5 mph. When the belt starts to slip you can see the header start to slow down a little then the header cut off shuts the header off. We just reverse the feeder house for a second and the turn it back on and we can go for a while with out it slipping and sometimes it will start to slip again after getting into the crop about 5 feet.
We've tried tightening the drive belt on the feeder house and the drive belt driven by the seperator. After tightening both of these the problem has not gone away, it has helped a little bit but not enough to make the problem go away.
Has anyone else had this problem before? Any idea what would be causing this?
I've never had that happen before, trying to think what could be causing it. Is the tensioner in good shape? Maybe there are some bushings worn out and that's causing some play in the arm that holds the tensioner pulley. Only other things I can think of are the condition of the belts and pulleys.
The belt on the feeder house and the driven pulley on the feeder house were replaced this summer. I think the tensioners are all in good shape and the bushing are all tight as well. We've tightened both feeder drive belts according to the book. Does the slip clutch for the feeder house ratchet or does it not make any noise when it starts to slip? Probly need to take a look at it after were done cutting in a few days. The combine has a long winter of work that needs to be done to it so it'll get a good look over when it gets in the shop.
