I have to replace the feeder drum. I have a standard drum with 3 strand chain. The center chain has punched a bunch of dents into the drum. Only in the center only. The drum is badly egged and needs to be replaced.
Question: Would switching to a stone retarder drum prevent this? I don't want to put in a new drum only to have it cave in in the center again.
Our feeder drum had three rows of dents so we welded three stainless strips (about 70mm or 3 inches wide) over the dented sections of the drum. Using stainless you can getaway with thin sheet, I think we used 2mm, 1/16 sheet. After 1000 hrs it is slightly dented but not worth worrying about. It does push the feeder chain forward but not much.
I'm glad your memory is better than mine Doorknob. If you search for that drum I believe you'll find mixed reviews. There are rubber/plastic strips that you can get to pop rivet to drum to prevent chain from wearing into it real bad. Since I use plastic feeder chain this doesn't happen as bad. We use he strips on our drums as they were wore when we bought our combines.
