When I try to calibrarte my header on my 2188 when I get to the part that lets the header down I get a code; Huo Open/short to ground-raise solenoid circuit failure. I have the corn head on and the header control works and the button in the cab works. Does this mean the raise solenoid is going bad and I should replace it or is there other posibilities?
For starters take your corn head off so it can do a proper calibration below ground level. Does it do it every time or have you only tried it once? Sometimes you can turn the key off and try it again. As for the code - sorry, I would have to look into it.
