1 - 2 of 2 Posts
So combining along last night and shut the header off to dump in the truck then go back to the crop hit the switch and only the reel came on.. ended up shutting the machine down and then it all worked normal after that.. has anybody else had a issue like this? I hope it’s a one time thing but in my experience it usually gets worse..
It usually will !! Have a look at the oil pressure sending switch on the front side of the engine - sounds kind of weird but for some reason if it malfunctions it can cause all sorts of hydraulic malfunctions . If it is oily change it .
1 - 2 of 2 Posts
