Hey guys, just looking for help here. I have a 2188 combine. Works fine after the first tank of the day. But during that first tank load the rotor speed will drop as well as the fan speed. Engine Rpms stay up. After about 3-5 mins of backing in and out the crop it will seem to warm up and go on working perfectly fine the whole day never doing this again. I have changed the PTO fluid and filter. Put a new solenoid on that block on top the PTO. Also the clutches were done 5-6 years ago but whether correctly I don't know. This problem as been on going for several years. If it was clutches going bad, they should be toast by now??? I know when this issue is going on, the seperator will be very very slow to engage. After the first tank load the seperator grabs and engages like it should.
Any ideas?? Tried about everything with no luck. Hate to redo clutches again and that's not the problem. Case mechanics are not cheap!
