Here's
an old thread I made with some pictures of a rebush. I have since changed a few things like removing the plate stiffener as I found it to make the rail frame work too stiff when the cross shaft has so much slop in its engineering. There are other machine changes I have made since also, but the rebush is about the same. I'll be doing a rebush on our second 1680 we just purchased, before next season and hope to take more pics and some video. But that wont help you now.
From what I see, you are the type that wants to learn and know how things work. So if you press your own, I would buy the die kit from CIH. Part #B96214 in
this catalog. I have one and after doing a rebush without it, it is an amazing tool set. I wont do another rebush without it. Not only for speed, but to reduce the risk of new bushing damage, which will require purchasing another new bushing.
A rebush is really only half of the needed R&R work to make your combine reliable. The shaker cross shaft and cams need replaced as well, but many see the price of the new shaft and choose not to change it. This is a mistake. But the shaft is nothing special and you might see if you can buy from A&I dealers or have one made.
IMO.
