My 2188 vertical unload auger broke, spun the hub loose from the auger on lower end (where gearbox splines go in). I have determined the augers weren't times right on top end, that didn't help this whole situation.
But anyway I have new vertical auger, new lower casting and gearbox. My gearbox isn't anywhere close to bolting up to the 8 bolt holes in the mounting casting. They are half a hole off at best. Doesn't seem to be much leeway to move gearbox around. I don't want to force it to bolt up or I think there will be quite a bind on the auger/splines/gearbox bearings.
Could my whole grain tank have sagged causing this mis-alignment to occur? I think I'm gonna drill out the holes bigger in the casting to try to get the bolts in that way.
Comments welcomed. Thanks
