my 2188 windshield wiper is slipping on the shaft is there a easy way to tighten up the nut or take off the roof?
Sure hope someone answers your question jof, I've got the same issue and have been into it somewhat without much luck either.
Loosen the jam nuts on the motor sticking out. When you do that then you can shove it back inside, then you can pop the cover off the front of the wiper, and then tighten the nut. Try to stop the arm straight down.
Todd
