currently have a single fan 2320 feeding a 42ft bar ,6 runs 57 tynes 9 inch spacing.
Looking at a 60ft C2 on 12 inch spacings it has 6 heads on it ,if I just adjust the drive ratio on the cart will the fan handle the extra width and extra product per run?
Normally 150kg product max per ha single shoot travelling. 9-10 kmh
Cheers
Assume 2320 is a Flexi-Coil?
If so no problem.
Yes, just change drive ratio sprockets.
In fact, no plugged manifold ports, even better.
You are only looking at 2700 kg/hr, piece of cake.
Thanks Don yep flexicoil, only other thing the secondary hoses will be 32mm id, no problem with that either?
You’re welcome.
Sounds quite large.
Why so large? Sounds like old Friggstad hose size, circa 1980.
The C2 was hooked up a to ‘Simplicity’ cart, Australian built which used the 32mm , most Morris stuff seems to be 32 mm over here I’ve noticed
