Are the finals on a 2366 the same as on a 2388? Also what all is involved in a 12 row ready package? Extra cyl and some weights, anything else?
CC
a 2366 can have a diferent # of bolt holes it could have 10 or 20 All 88s have 20 holes in the wheel hub There is a cone on the clean grain elevator cross auger to funnel in the grain on a 12 row ready machine
12 row ready version also has a different steering motor as well to go with the dual cylinders on the rear axle. The final drives that have 10 bolt holes are standard version and the 20 bolt hole version is HD with 100 lbs more cast in the housing and roughly 2" larger dia output shaft. The HD version final drive was an option on the 2366 and standard on the 2388
We had a 2005 2388 12 row ready and like the other guy said all that stuff
It turns like a plane.... lol
i guess it would be fine on a 12 row corn head.
it also had the extended wear package on it and better tires (looks wise) than any of the other combines we get.
