1 - 9 of 9 Posts
I have a 02 2388 and the afs monitor is giving me problems. The touchscreen works sometimes, then the next day it wont. Ive tried cleaning the screen good and that doesnt help. Anyone have this problem before?
I dont know the model but its about an 7 inch black and white screen.
My guess would be that the screen is starting to "de-laminate", it will probably need to be sent to ag express for repair. when its not working you might try squeezing the left side about 1/3 of the way down with one hand and pressing other buttons it may let it work.
you say 7", which is right between the two sizes CIH actually offered (5.5 and 9.5). So I'm not sure which one you actually have. The one that had the most problems was the larger one. Either way, what you're seeing is likely delamination. Squeeze the upper left corner of the display (on the black bezel around the actual touchscreen), and try to operate the display while you're squeezing it. If this works consistently, then it's a pretty sure sign that delamination is the problem. As a temporary fix, you can GENTLY use a C-clamp to apply pressure (use a couple of cardboard pads to protect the display). AgExpress can repair these displays if you have time to send it in. Or you can update to the Pro 600 and have the color display, option to run autoguidance, etc.
1 - 9 of 9 Posts
