When cutting wheat, when the temp guage gets to the first line the air intake temp warning light comes on. Last fall after harvest I pulled the rotary air screen off (rear mounted) and cleaned the cooler with the power washer, the radiator is clean. I can't figure out why it keeps going off. Tried new sensor last fall in soybeans, did'nt help, put on new fan belt on Monday, nothing.
The fan bearing went out for the previous owner and the fan got into the shroud a little, I took it out and fixed it with fiberglass thinking I had the problem fixed and still no luck. Mech says to try a new header control box, before I spend $$ on that does anyone have any suggestions?
