If I remember correctly they recommend something like 1300 or 1400 pounds of ballast for a 36' header. We only run 600lbs of cast iron on the back and it isn't enough, but with fluid in the tires along with your heavier iron you should okay. It'll be a lot better than ours, at least, and we get along pretty good as is.
edit: My mistake, the manual says 1800lbs ballast for a 2052 with gauge wheels and plastic tine reel. It says to add 400lbs for steel tine reel and 300lbs for the transport package. I think a 2062 is a little heavier.
