I am new to IH combines and I have a 2388 with a 30ft 2062 header and the drop rate is to fast even with the setting turned all the way down, Is there a simple fix?
does the drop rate knob slow it down at all? Just wondering if the knob worked at all. You could switch the raise and lower knobs to test them. How many cylinders are you running? A third cyliner kit would slow it down and help it lift. The knob should slow it down enough.
It has 3 cylenders on it and the knob soes have some effect but not near enough.
the easiest thing to check would be to swap drop rate knobs from raise to lower. Also check the header controller calibration. Make sure it is calibrated corectly. What mode are you using? Manual rtc or float?
