does anyone have the lever or mechanism to lock the header on so you don't have to crawl under every time? Does it work pretty well? do u have to put something on the head? any other info would be great...thanks
Yes, works very good and you do need to have a kit for each head to complete and if your feeder housing isn't pre-drilled (2007 model or newer) it is a bit more work to install. The old latches have to be removed and the new ones have to be welded on to the feeder face bottom. There is a kit for a tracker equipped combine and a different kit for a non-tracker equipped combine.
They should have had this design 30 years ago.
