Anyone ever had trouble with one of these bypassing? My combine is not pulling right in 2nd or 3rd it sounds like oil bypassing right under my left foot.
You should replace the needle and seat in the inching valve. Then recheck the pressure before adding shims. 6500 to 7000psi
It must be the presurre releave valve. I'm not sure but I think u activate that when u step on the inching valve. Anyway you can shime up the pressure releave valve but u have to hook up a pessure gauge to chech it. Factory setting was about 6900 psi for a 2388, I've gone up to 7400 without trouble. Helps alot when u have rear wheel assist and run in a lot of mud.
