The return-to-cut feature on our '04 2388 quit working the other day. Not sure of the cause. Has anyone else dealt with this and if so what was it that fixed it? TIA
Note the arrows will not show up until you are hooked to a head and AHHC wires from head are plugged into combine. Be sure to do the 5 second quick call alsoI have the same issue on a 2166. No RTC or AHHC since I bought it last winter. Probably quite on last owner.
I have replaced both the pot on the feeder and the selector knob in the cab. Went through the calibration process and everything seemed to be already set correctly. Height display numbers work fine but NO arrows no matter what I do with the selector.
Hope someone can help us out!
5 second quick call?? What is this?Note the arrows will not show up until you are hooked to a head and AHHC wires from head are plugged into combine. Be sure to do the 5 second quick call also
