I was wondering if I could ask some advice.
We have a 2001 build 2388. The rotor has had alot of vibration for sometime now, this is my fault I think, as I fitted extra teeth to the rotor where they appeared to be missing, and has unbalanced the rotor.
Removing 3 teeth has balanced the rotor, but the horseshoe shaped bracket between the gearbox is broken, as is the mounting it is bolted too.
Does anybody has any advice as to how I would go about and fix it please? I wasn't very keen to weld it in place as it would be difficult to get a good weld and fire.
Thank you in advance
David
David
