I have a few questions for anyone that may run a fm1000 monitor from trimble in their case 2388. I have a 01 and had a trimble rep "install" the fm1000 monitor from our planter tractor into our combine. The wire harness was hooked up wrong from the get go, long story short i am no longer getting service out of them. i messed around with it and got the harness plugged in the correct way, only thing i notice is that when i shut the monitor off, it says "clean out moisture sensor, yes or no?" when i click yes, nothing happens with the moisture sensor(case ih unit). Should this turn? I haven't gotten the chance to field test the unit yet to know if the little auger is turning while in regular use. I also notice when i make the light work on the back side of the proxy switch light up, nothing happens. (key power on and monitor on). But if i take the 40 amp relay out and jump the wires like ag leader says, the auger will turn. is there something I'm missing? two weeks and i still have a pos trimble system.
