[quote author=casefarmer board=Case thread=1136385605 post=1136410787]I just wish they would make some changes......on a few problem area's
We rotate 2 2388's each year and you can basically mark down what problems you will have after so many hrs
Also HOW ABOUT MAKEING THE HOPPER AUGER HEAVY DUTY
stop with this then metal flighting crap (however you spell it)
I do think from what i read on a fax that they are addressing a few things.
This past year we had a terrible time with the Slip Clutch on the clean grain elevator and im still not reall sure why
Bad luck i guess
Anyone add those extra augers to take stress off of the hopper auger
? (how did it work?)
just curious[/quote
Casefarmer,
Yes,if you use a bubble up auger in the grain tank it will take the stress off of the hopper auger. It will help to keep the clean grain elevator from slipping and plugging.
I've found that in high bushel per hour situations, when the grain tank is nearly full and you are using a bubble up auger, that you can still plug the clean grain elevator.
