in the beginning of air seeders and such we always used 3/4 couplers as not only did they flow more and reduce heat, they were dedicated to the circuit,,, as far as a brand flow control valve, they have been around forever, what they are is a pressure compensated valve that has a floating spool that adjusts flow regardless of the pressure to give the controlled flow port consistent gpm. they work very well, have great adjustment, have a lock on the adjuster, and have the capacity to shunt the excess flow to another circuit without losing gpm on the main. they are simple and reliable. all of these controls and couplers are readily available at any good hydr shop, and at most any major ag/industrial supply. hose size should also be upped on the fan circuit, as well as minimizing any fittings that impede flow, usually a fan drive needs a third case drain line as well that has minimal if any restriction and returns directly to the hydr tank, this is like a c/case vent on an engine and is an important part of the circuit as well as an indicator of wear in the fan motor..
