Does Anybody know if I can upgrade my signal to rangepoint on my 372 receiver on my sprayer with viper pro, and then move that same 372 receiver to my 4WD? My plan would be to use it in the 4WD for seeding then switch it to the sprayer for the rest of the year. Can't just upgrade the 4WD to rangepoint because it only has the 262 receiver. Was hoping to just switch the two receivers for seeding? Any info would help. Thx
Yes this will work. You will need a dealer or someone who knows how to operate ag remote to format the 372 every time you switch it between vehicles.
Remove it from the sprayer and put it on the 4wd, it will work. To put it back on the sprayer, the ports need to be reformatted.
· Premium Member
If you have a 750 you would be better to hook it to range point and it can feed the viper pro or be moved/used in the 4wd without the dealer having to come out and set it up each time. By time you pay for service calls it can get expensive to move the 372.
It's possible to hook the 750 to the tractor with the 262 receiver and pick up rangepoint? Is this difficult to do? This would be the better option, then I could put the 750 in a different unit after seeding.
· Premium Member
Why would you not just use the 750 to do everything for the tractor and forget about the 262 in the tractor or am I missing something? That is what I do for seeding and then I use the 750 to input the prepay signal into the viper pro for the sprayer.
